Thanks Alex. Looking at at you diagram there is a purge valve I found similar diagram (minus a clearer hose detail) it was called intake manifold runner control valve I xalled mazda with the vin# and they called it runner valve as well for $160 so I called a few parts stores 1 or 2 had runner valve others did not autozone has it as part pv780 for runner valve (my diagram which I didnt print out) and pv769 for purge valve (your diagram) tge one on there now is the purge valve is NOT the orignal I changed it last year and it is chattering again. My question although I think they are both purge valves which one is the correct valve the runner or the purge as of now I have evap leak and a dead cylinder#2 im going to check the coil but could this faulty valve cause any of these issues thank you for help
Monday March 4th
Monday March 4th
Mar 5, 2019 at 12:04 AM
