Here are the directions for seat removal. The attached pictures correlate with these directions.
Seat
Exploded View
NOTE: Manual seat shown, power similar.
see picture 1
see picture 2
Removal
1. Remove the LH and RH quarter trim panels. REFER to Trim Panel, Quarter Trim Panel - Without Inflatable Safety Belts or REFER to Trim Panel, Quarter Trim Panel - With Inflatable Safety Belts .
2. Connect the third row power fold seat control switch, if equipped.
3. NOTE: If equipped with inoperative power seat, Refer to Manual Override of Inoperative Power Seat- 3rd Row See: Seats > Procedures > Manual Override of Inoperative Power Seat - 3rd Row.
Position both seats to the load floor position.
4. NOTICE: If equipped with a power seat, do not lift the load floor flapper panels too far or damage to the wire harness retainers will occur.
Separate the 2 load floor supports (1 shown).
- Push the load floor support rearward and slightly lift the load floor to disengage.
see picture 3
5. If equipped, disconnect the electrical connector and detach the wire harness retainers.
see picture 4
6. Detach the 2 wire harness retainers on the RH side.
see picture 5
7. Remove the four mounting bracket-to-floor bolts and remove the third row seat.
Installation
1. Install the third row seat and the 4 mounting bracket-to-floor bolts.
- Tighten to 80 Nm (59 lb-ft).
2. If equipped, connect the electrical connector and attach the wire harness retainers.
3. Attach the 2 load floor supports.
4. If equipped, disconnect the third row power fold seat control switch.
5. Install the LH and RH quarter trim panels. Refer to Trim Panel, Quarter Trim Panel - Without Inflatable Safety Belts or refer Trim Panel, Quarter Trim Panel - With Inflatable Safety Belts .
________________________
Aug 25, 2020 at 12:56 PM
(Merged)
