Engine run fine. Then I added a drop of dielectric to coil boots and tighten spark plugs. While doing it I accidentally shorted to ground the PCM wire (not the second 12 volt wire) on one of the fuel injectors.
Now, after I fixed the short on the wire:
1)With engine running, still, there is a very thick white smoke and gasoline coming from tailpipe. Seems like, there is also a little bit of a gas smell under hood.
2) Resistance of all fuel injectors is around 12ohms.
3) When Key is in ON position, I measure DC around 3.4V on the PCM wire and 12Volts on the common wire of all fuel injectors.
Is PCM wire reading of 3.4V normal?
What do you think got damaged?
I am thinking it might PCM, PCM driver, might be the new coil boot dielectric, might be over tightened damaged spark plugs, or I might have pulled something else while doing the work.
Thank you
Thank you
Sep 28, 2019 at 4:33 AM
