thermostat replacement
2003 FORD THUNDERBIRD
106,000 MILES • 3.9L • V8 • 2WD • AUTOMATIC
KELBAR09
In addition to thermostat replacement, I also will be replacing the coolant part it mounts to. My question is: since there are other items close to the area, some wiring, hoses, etc., is it best to disconnect the battery first, and, when finished and battery re-attached will anything need to be re-programmed?
Aug 17, 2017 at 9:30 AM
Yes it is best to disconnect the battery and there should not be any reprogramming necessary.
Here are a couple of guides to help you get the job done:
https://www.2carpros.com/articles/how-to-replace-a-car-battery
and
Diagrams (Below) show you what its like on your car.
Aug 17, 2017 at 4:18 PM
