Which engine do you have? I show two options. 2.3L or 3.3L. I attached the process for the 2.3L. Our manual didn't have the specific process for the 3.3L so I assume that will be the one you have.
However, the thermostat is normally allows just at the other end of the upper hose. One end is attached to the radiator and the other is connected to the thermostat housing. Then the thermostat is in the housing.
Let me know if you have another engine then listed and I will see what we can find. Thanks
Mar 5, 2020 at 3:43 PM
