Overheating after replacing thermostat
2001 INFINITI QX60 HYBRID
150,000 MILES
SUSIE URIBE
Had thermostat replaced and it started overheating so then had the other thermostat replaced and still overheating? What could be the reason? It never overheated on me before. The only reason I had the thermostat replaced was because the car took a long time to warm up and the heater also took it's time on heating up. Now I can't even drive it because of it overheating. Could anyone please help me out with this problem? I really need it..
Nov 9, 2019 at 6:18 PM
Sounds like you have an air pocket. I would recommend starting with getting a funnel shown to ensure you are pulling coolant in when the air is working itself out. You can get these funnels at most parts stores.
Here is a video that shows how to use it:
https://youtu.be/7n5zE4ObQeE
The other thing I would try is while you are doing this, jack up the corner of the vehicle closest to the radiator cap. This will cause any air that is trapped to work towards the highest point.
Nov 9, 2019 at 6:48 PM
MASTERWRENCH
  • 258 POSTS
Replacing the thermostat was definitely the correct repair direction for your initial slow to heat up condition. However, based on the fact that the engine never overheated until the new thermostat was installed, I'm lead to believe that it may be defective. I would suggest having the same shop who installed it, remove it verify that it's opening properly. That's really the only thing that makes sense at this point. I've attached the thermostat replacement procedure just in case you need it.
Let us know how you make out!
Nov 9, 2019 at 6:58 PM
SUSIE URIBE
Yes, my son took the thermostat he put in because of it overheating and he got another one. And it still overheats. This is what I don't understand? Could it be something else?
Nov 9, 2019 at 7:32 PM
MASTERWRENCH
  • 258 POSTS
I would follow KaseKenny's instructions regarding air pockets. That certainly is a possibility. Have your son take a look at the instructions I attached to verify that the thermostat was installed properly too.
Nov 9, 2019 at 7:56 PM
