First, be sure to get that oil and gas out of there so it doesn't wipe out the bearings. Next, leave the lines connected to the fuel pump if possible, then unbolt the pump and pull it back. I'm bettin' you'll find gas running down the lever. The only other way for that much gas to get in the oil is to have it overflowing the float bowl and running into the intake manifold. If the engine runs okay otherwise, we know that isn't happening. Those engines used to have a common problem with carbon blocking the exhaust passage through the intake and under the carburetor. That made the thermostatic choke remain closed. If the engine did run after it was warmed up, it ran so bad and there was a huge cloud of black smoke from the exhaust. Even that seriously over-fueled mixture wasn't enough for much gas to accumulate in the oil. You got it much worse than that. I can't think of any other way besides the fuel pump to get that much gas in the oil. I'd expect this even more from a recently-replaced pump than one that has been working fine for years.
Jun 8, 2024 at 9:28 PM
