There was a lot of high water and flooding, so my car shut off...Immediately the check engine light went on as well as another, I believe for the exhaust (or something similar). After a minute or so, I turned the key in the ignition and it started again and I was able to get out of the water and the light went off. Now, there is a slight chugging noise and I don't know if its because there's water in the engine. Does it need to drain overnight? Would the check engine light be on if there was water in the engine?
Thank you!
Thank you!
Jun 11, 2014 at 7:44 PM
