Hello again,
Okay, here it is again. As before, I have the two wires HIGHLIGHTED for you. If you look at the wiring diagram, the two big dashed boxes are the ignition switch, and the I/P fuse box. these are the wires you ask for. Here again, is the wiring diagram for the starting circuit. If you start at the battery and follow the HIGHLIGHTED wires you will see that the electrical path goes through Maxi Fuse 6(40A) of the Underhood Fuse Relay Box and Crank Fuse 8(10A) of the I/P fuse box. I have also included the diagrams and callouts for the fuse boxes in the diagrams down below as well. Please go through these guides and get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
Jul 22, 2019 at 12:32 AM
