Dears, I would like ask you a question about the theoretical possibility of key cloning.
As I have read on the internet about making an additional copy of your key or just a remote, in case for this car you must have two original keys (to be able program third directly on the car) but I have ony one.
If there is a procedure to reprogram your original key with some procedure (turn on-off six times within ten seconds...) would it act as a trick (if you have new cutted key with blank chip/transponder) to make the same procedure to other key and after that both be functional as clones?
Thanks for your patience, time and answer.
Best regards, Marjan - North Macedonia
Jun 15, 2023 at 12:43 PM
