Here are the directions for reprogramming the new key without a scan tool. Take a look through it and let me know if it is what you have already done. Also, I'm not sure what you mean by elecring. I attached a pic below. Do you see the part that was replaced?
______________________________________
KEY PROGRAMMING - NEW KEY (Without Diagnostic Tool)
NOTE: Before starting this procedure, make sure the key(s) your want to program have the correct mechanical cut.
1. Insert the nonprogrammed key in the ignition and turn to RUN.
2. THEFT indicator proves out after 2 seconds and then flashes rapidly.
3. After 15 minutes of flashing, the THEFT indicator will stop flashing.
4. Within 5 minutes after the THEFT indicator has stopped flashing, turn the ignition key to OFF and back to RUN.
5. THEFT indicator proves out after 2 seconds and then flashes rapidly.
6. After 15 minutes of flashing, the THEFT indicator will stop flashing.
7. Within 4 minutes after the THEFT indicator has stopped flashing, turn the ignition key to OFF and back to RUN.
8. After 15 minutes of flashing the THEFT indicator will stop flashing.
9. All originally programmed keys are now erased, and the key in the ignition is now programmed.
10.Additional keys may be programmed using the Key Programming - Spare Key Procedure.
Let me know if that helps.
Nov 29, 2020 at 8:16 PM
