Theft deterrent module preventing new re-manufactured engine from starting
2004 BUICK RENDEZVOUS
167,000 MILES • 3.4L • 6 CYL • AUTOMATIC
OSILVERA200
I took the car for a long block (re-manufactured) replacement. Now the car does not start. The shop says it’s the theft deterrent module. How can I reset it or do I have to replace it?
Aug 28, 2020 at 2:32 PM
Is the anti-theft light staying on all the time? Was this a problem prior to the repairs?
As far as the anti-theft module, it is located on the steering wheel. There are two ways to reset it. One is with a scan tool and the other without.
I am going to provide the directions for relearn procedure without a scan tool. It will take 30 minutes to complete. Follow the directions below.
________________________________________________________
30-MINUTE RELEARN PROCEDURE
Use this procedure after replacing the following components:
- The passkey III (PK3) keys
- The theft deterrent control module
- The PCM, see important above
IMPORTANT: This procedure is not available on vehicles equipped with option code (Z49 or BAE).
If replacing a theft deterrent control module with an GM SPO Replacement Part, perform the procedure to setup a new theft deterrent control module prior to the 30-minute relearn procedure.
1. With a master passkey III key (Black), turn ON the ignition, with the engine OFF.
2. Observe the Security telltale, after approximately 10 minutes the telltale will turn off.
3. Turn OFF the ignition, and wait 5 seconds.
4. Repeat steps 1 3 two more times for a total of 3 cycles or 30 minutes.
IMPORTANT: The vehicle learns the key transponder information and/or passwords on the ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle.
5. With a master passkey III key, start the vehicle. The vehicle has now learned the key transponder information and the PCM has now learned the fuel continue password.
6. With a scan tool, clear any DTCs.
If the module needs replaced, here are the directions for that process. The attached pictures correlate with the directions. Note that the new module will need programmed.
2004 Buick Truck Rendezvous AWD V6-3.4L VIN E
Procedures
Vehicle Accessories and Optional Equipment Antitheft and Alarm Systems Alarm Module Service and Repair Procedures
PROCEDURES
THEFT DETERRENT CONTROL MODULE REPLACEMENT
REMOVAL PROCEDURE
1. Disable the SIR. Refer to SIR Disabling and Enabling Zone 3 in Restraint Systems.
2. Remove the trim covers.
3. Remove the theft deterrent module wiring harness from the steering column harness.
4. Disconnect the electrical connector.
pic 1
5. Pull the theft deterrent module (2) away from the lock cylinder housing (1).
INSTALLATION PROCEDURE
pic 2
1. Push the theft deterrent module (2), onto the lock cylinder housing (1).
2. Install the theft deterrent wiring harness to the steering column harness.
3. Connect the electrical connector.
4. Replace the steering column trim covers.
5. Enable the SIR system. Refer to SIR Disabling and Enabling Zone 3 in Restraint Systems.
6. Program the new theft control module. Refer to Programming Theft Deterrent System Components. See: Vehicle > Programming and Relearning
Aug 28, 2020 at 2:57 PM
