The vehicle indicate ABS plus acarslp dash board
2016 TOYOTA LANDCRUISER
60 MILES • 4.8L • V8 • TURBO • 4WD • AUTOMATIC
KEVONI
Also the speed meter dose not move at all.
Sep 22, 2019 at 12:20 AM
MASTERWRENCH
  • 258 POSTS
Welcome to 2CarPros.
It sounds like your vehicle has an issue with the ABS module or one of its sensors. The speedometer receives it's vehicle speed signal from the ABS module, so these two conditions are likely one in the same. To best way to pinpoint the issue is by retrieving the ABS Diagnostic Trouble Codes. However, this will require the purchase of a specific code reader that is compatible with your vehicle. If you don't have a code reader or would rather not purchase one, there are a few easy tests you can perform with tools you likely already have. Please see the link below for more information.
https://www.2carpros.com/articles/abs-warning-light-on-easy-repair-guide
Let us know what you find!
Sep 22, 2019 at 10:03 AM
