The transmission is stuck between 4t and 5th.
1986 NISSAN TRUCK
270,000 MILES • 2.4L • 4 CYL • 4WD • MANUAL
GUADAMOUR
I recently purchased this vehicle and I hadn't check the tranny. I was driving in 5th and was unable to down shift. I discovered the tranny was dry. Clutch works fine. Is this rebuild-able or should I look for another tranny? Would it be the shifting fork is broken, or the bearings froze?
Nov 17, 2015 at 10:08 AM
it is rebuild able but very expensive. I would go to www.car-part.com and find a used unit to replace.
Nov 22, 2015 at 9:06 AM
