This is monitored by the navigation module, is there anything else that is not working? I would check all operations of the navigation to see if everything works. Also, let's check the fuses for system #36, 29 and 18 in the fuse panel on the left end of the dash. here is a guide to help and the fuse location in the diagrams below. If the fuses are okay a CAN scan will help you confirm the failure of the Nav module.
Here is how to do the CAN scan; it has a video in the guide:
https://www.2carpros.com/articles/can-scan-controller-area-network-easy
Apr 29, 2022 at 9:53 AM
