The speedometer, gauges and warning light are not working, fault code: DIM E003 and CEM A156?
2002 VOLVO S60
213,567 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
MALLYBOY
  • 327 POSTS
The gauges, speed clock and instrument warning lights do not work. I checked the power and ground to the clock, there was power but the communication line I has not check.
Aug 14, 2023 at 11:42 AM
DIM E003: This code indicates a fault in the Driver Information Module (DIM).
CEM A156: This code points to a problem in the Central Electronic Module (CEM).
So, I would start by checking the fuses this guide can help:
If the fuses are good chances are the IPC (DIM) has gone bad, here is how to change it out in case you need it. Check out the images (below). Let us know what happens and please upload pictures or videos of the problem so we can see what's going on.
Aug 15, 2023 at 9:28 AM
MALLYBOY
  • 327 POSTS
From the description, it was referring to communication line faulty, there are no communication between those modules. The DIM was replaced with a used one and I used scanner to actuate the gauges, lights and warning lights and it all worked. Then I reset the fault code and cycle ignition twice and rescan and the code appears back before I decided to check the communication line first before any other thing. Does it need to be programmed when replaced?
Aug 16, 2023 at 12:36 AM
Yes, it does need to be programmed.
Aug 16, 2023 at 11:52 AM
MALLYBOY
  • 327 POSTS
Yes, it does need to be programmed. What special function of the scanner will I use for the programming or how do I program it with scanner?
Aug 16, 2023 at 2:10 PM
Sure, here is a good one for only $1,100.00, the snap on version costs $7,500.00.
https://amzn.to/3KKIFID
Aug 17, 2023 at 10:03 AM
