Rear end pops when you turn
1984 FORD MUSTANG
67,825 MILES • 0.5L • V8 • 2WD • MANUAL
LEEHAMM3657
It just started you can feel it in the car.
Feb 2, 2018 at 4:03 AM
CJ MEDEVAC
  • 11,004 POSTS
Does it have a posi-traction rear end? This happens when the sider gears or locked up.
The Medic
Feb 2, 2018 at 5:43 PM
LEEHAMM3657
Yes and something popped loud and the drive shaft moves but do not move.
Feb 2, 2018 at 6:03 PM
CJ MEDEVAC
  • 11,004 POSTS
You are saying that when you let the clutch out, the driveshaft rotates, the vehicle does not move.
I have to ask this one! Were you dogging it out when it happened?
The Medic
Feb 2, 2018 at 6:29 PM
LEEHAMM3657
No, i did have to give it a little because car was coming. i was in town and my car is loud.
Feb 2, 2018 at 9:12 PM
CJ MEDEVAC
  • 11,004 POSTS
In the beginning, I was going to suggest that maybe your differential was "popping" because that maybe your posi-traction differential lacked hypoid fluid (needed changing + hypoid additive) or needed to be driven in tight figure "8"s to lubricate the clutch discs within the differential.
After your second response, I am now leaning towards something broken within the differential (not good) or maybe you broke an axle (a little bit better!).
The Medic
Feb 2, 2018 at 11:01 PM
