Maybe you can get someone to help you upload some pictures for me to see.
At this point, I am going to give you pictures of the compressor as it does sound like you will need to replace the compressor.
https://www.2carpros.com/articles/replace-air-conditioner-compressor
REMOVAL
1. RUN ENGINE AT IDLE SPEED WITH A/C ON FOR APPROX.1O MINUTES
2. STOP ENGINE
3. DISCONNECT NEGATIVE (-) TERMINAL CABLE FROM BATTERY
4. DISCHARGE REFRIGERANT FROM REFRIGERATION SYSTEM
5. REMOVE DRIVE BELT
6. 1MZ-FE engine models:
REMOVE SUCTION HOSE
a. Remove the suction hose clamping bolt.
b. Disconnect the wire harness clamp.
c. Loosen the nut and bolts and remove the suction hose.
NOTE: Cap the open fittings immediately to keep moisture or dirt out of the system.
7. 1MZ-FE engine models:
DISCONNECT DISCHARGE HOSE
Remove the bolt and disconnect the hose.
8. 1MZ-FE engine models:
REMOVE GENERATOR
a. Disconnect the generator connector.
b. Remove the nut, and disconnect the generator wire.
c. Disconnect the wire harness from the clip.
d. Remove the pivot bolt, plate washer, adjusting lock bolt and generator.
9. 5S-FE engine models:
DISCONNECT DISCHARGE AND SUCTION HOSES
Remove the 2 bolts and disconnect both hoses.
NOTE: Cap the open fittings Immediately to keep moisture or dirt out of the system.
10. 5S-FE engine models:
REMOVE COMPRESSOR
a. Disconnect the connector.
b. Remove the 3 bolts and compressor.
11. 1MZ-FE engine models:
REMOVE COMPRESSOR
b. Remove the 2 bolts, nut and drive belt adjusting bar bracket.
c. Remove the 3 bolts and compressor.
Apr 25, 2020 at 6:33 AM
