The light next to clock is flashing
2007 FORD BANTAM
240,000 MILES • 1.3L • 4 CYL • 4WD
TERENCE10
The Bakkie was starting the Tuesday night I switch it off when try to start it the Saturday the ignition is going on, but no power or movement on motor.
Jul 11, 2018 at 9:19 PM
STEVE W.
  • 15,113 POSTS
Does the light flash different when you try the key? What symbol is on the light? It sounds like it could be a security light, if it stays flashing when you use the key it is likely to be a malfunction in the system. Have you tried a different key?
Jul 12, 2018 at 1:15 AM
