The U110E code is for a loss of signal from the ambient temperature sensor. I do not think that is the cause of this problem.
U1114 is an issue with the fuel volume signal. It is implausible and the PCM cannot recognize it.
U1411 is a lost or no signal from the ABS module.
U1120 is the same as U1411
U0101 is a lost communication with the transmission control module (TCM)
U110c deals with a loss of communication with the fuel level sensor.
Okay, none of these is going to cause the engine to not shut off. However, all of these have a couple things in common. The information supplied is through the CAN C bus. The CAN C bus is made from two twisted pair wires that are 22 gauge in diameter. The CAN C Bus (+) wire is white with a light green stripe and the CAN C Bus (-) is white with a light blue stripe. Yes, this is located in wiring loom. I believe you either have a broken or damaged wire in this set of wires. If you go to the following page, it provides all of the wiring schematics for your vehicle. At that point, it is a matter of tracing wires to see if that is where the problem is from.
http://www.rambodybuilder.com/year.pdf
In addition, the other common issue with all these codes is a bad PCM.
Oct 13, 2014 at 5:42 PM
