Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Nissan
X-Trail
Engine
Symptoms
Coolant In Oil
The engine is mixing water and oil again
2005 NISSAN X-TRAIL
130,000 MILES • 2.0L • 4 CYL • 2WD
MOTHAE
MEMBER
FOLLOW
I have just replaced a cylinder head casket and it ran well when started the first time but eventually mixing oil and water again in hours.
Aug 13, 2019 at 2:08 AM
MOTHAE
MEMBER
It seems to have been throwing a lot of pressure to the coolant and disturbs a normal flow of water throughout the cooling system.
Aug 13, 2019 at 2:23 AM
SCGRANTURISMO
CERTIFIED EXPERT
When you changed the head gasket did you get your cylinder head shaved at a machine shop?
Thanks,
Alex
2CarPros
Aug 13, 2019 at 2:25 AM
MOTHAE
MEMBER
Yes, it was skimmed and pressure tested with new valve seals.
Aug 13, 2019 at 2:29 AM
SCGRANTURISMO
CERTIFIED EXPERT
Hello again,
Okay, so let's do a compression check and make sure that the head gasket took. Here is a link for you to go to down below explaining how to do it:
Please go through the guide and get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
Aug 13, 2019 at 3:31 PM
