Can someone tell me about functionality of crank position sensor? because I have removed it and as I measure it was fault. But when I bought new one it shows weird measurements. The old sensor measures 1.5k Ohm between positive and ground pin, and when attached to 12v, on the signal pin it shows 1v. I put a hand mixer in front of it to stimulate metal part moving, but the voltage does not change. The new sensor measure 1.5K the same, and when put 12v input, on the signal pin it also show 12v. When testing with the mixer it also not change.
Oct 28, 2020 at 5:48 AM
