testing coil near plug
2003 GMC SIERRA
200,000 MILES • 6.0L • V8 • 4WD • AUTOMATIC
GREMLIN_MECH
how to test coil near plug coil
Apr 8, 2016 at 2:23 PM
HMAC300
  • 48,601 POSTS
with an ohm meter see video attached https://youtu.be/1zQQy9noYQ0
Apr 8, 2016 at 3:37 PM
AUTOTECHCHICK
  • 8 POSTS
You could test it as in the video posted above, but the easiest way is to swap it with a coil from another cylinder. Then, by monitoring a scan tool, check to see if the misfire has moved along with the coil.
May 11, 2016 at 8:22 AM
