The vehicle listed above is an S (supercharged) Battery is good, but the charging system light is on. Tested voltage at battery posts while running, and it was below 13, so it looks like battery isn't charging. I had to remove the charge air cooler to access the connector plug and post from the top. I want to test voltage from the post, before assuming the alternator is toast, but can I safely run the engine with the air cooler removed? Can't access the buried alternator with the cooler in place.
Sep 6, 2023 at 10:02 AM
