I'm getting misfires on cylinders 2 and 6 which share the same coil. P0302 and P0306. Rough idle has gotten progressively worse over the last 3 weeks. Changed plugs, then plug wires, then coil pack. Still getting the same codes and engine is getting worse. I get weak spark with probe from cylinders 2 and 6, on both the previous coil pack as well as the new coil pack. I read to test the wires running from the coil pack to the pcm. If the wires are good, then I may have a bad PCM. I have no experience with electrical or using multimeters.
How do I test the 3 wires? I know the pin locations on the PCM connector, I just don't know how to test the wire. I assume with a multimeter, but do I disconnect the wires from both sides? Am I connecting the multimeter to both ends of the wires (one by one) simultaneously to form a loop? Please explain as if I'm a 4 year old.
Aug 18, 2023 at 11:13 AM
