Terrain management fault
2011 FORD EXPLORER
99,000 MILES • V6 • 4WD • AUTOMATIC
CBARBER
When starting the car this light comes on: Terrain management fault.
Nov 12, 2017 at 7:39 PM
There is a problem with the a sensor or controller. Please scan the system of codes. If you scan the ABS system it should come up with a code that we can use to fix the problem.
https://youtu.be/rTtAnsOlZU4
Please run this test and get back to us.
Nov 15, 2017 at 6:38 PM
