When starting the car this light comes on: Terrain management fault.
Nov 12, 2017 at 7:39 PM
CERTIFIED EXPERT
There is a problem with the a sensor or controller. Please scan the system of codes. If you scan the ABS system it should come up with a code that we can use to fix the problem.
