Blower temporary rattling noise
2011 KIA SORENTO
100,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
22DRUMMER
Whenever I turn on the blower and try to use the upper cabin vents I get a rattling sound for about 6 seconds and then it stops. I removed the squirrel cage and it still rattles for about 6 seconds.
Oct 1, 2019 at 9:35 AM
Good afternoon,
This sounds like the actuator motor that is making the noise.
It is under the left side of the dash and a couple of things have to be removed to access the actuator.
Inspection
1. Ignition "OFF"
2. Disconnect the connector of mode control actuator.
3. Verify that the mode control actuator operates to the defrost mode when connecting 12V to the terminal 3and grounding terminal 4.
4. Verify that the mode control actuator operates to the vent mode when connecting in the reverse.
5. Check the voltage between terminals 5 and 6.
It will feedback current position of actuator to controls.
6. If the measured voltage is not specification, substitute with a known-good mode control actuator and check for proper operation.
7. If the problem is corrected, replace the mode control actuator.
Replacement
1. Disconnect the negative (-) battery terminal.
2. Remove the crash pad side cover(A).
3. After loosening the crash pad lower panel mounting screws, remove the lower panel (A).
4. After loosening the mounting bolts, then remove the reinforcing panel (A).
5. Disconnect the mode control actuator connector after removing the air duct.
6. Loosen the mounting screws and then remove the mode control actuator (B).
7. Installation is the reverse order of removal.
Oct 1, 2019 at 1:38 PM
22DRUMMER
Thanks, I will check that out and let you know what happens.
Oct 1, 2019 at 10:28 PM
You are welcome.
Always glad to help.
Oct 1, 2019 at 10:53 PM
