Temperature sensor wiring lead color code - engine wiring
2007 NISSAN NAVARA
3,000 MILES • 3.0L
AUTO SUPREMACY-THE MAESTRO
  • 15 POSTS
May you please help me with the color code of the lead that feeds into the coolant temperature sensor of the vehicle listed above? The loom was tempered with. So I'm failing to locate it.
Jun 11, 2020 at 4:14 AM
Here are the engine wiring diagrams which feature the coolant sensor wire colors and a guide to help you test the wiring once repaired:
Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
Jun 12, 2020 at 10:47 AM
  • 15 POSTS
Thanks a lot,but there is this other temperature sensor with a single lead that feeds into it. This in particular is the one I am inquiring on. I thank you.
Jun 13, 2020 at 11:00 AM
Can you please shoot a quick video with your phone so we can see what's going on? that would be great. You can upload it here with your response.
Jun 17, 2020 at 9:19 AM
