Temperature sensor and ECM
2015 KIA RIO
607,880 MILES • 1.2L • 2WD • MANUAL
CID6688
  • 9 POSTS
Description of Problem: I scan . P0118 KIA - engine coolant temperature sensor 1 circuit high input. Well, sir, my cooling fan has broken down. Now I replaced a new assemble cooling fan when I started the engine simultaneously with the cooling function it did not trip off. The A/C was not cool too. Even the temperature gauge is not working. Now I replaced the new temperature sensor. I still have the same result. The other mechanic said the engine computer module might be faulty. Then by checking the ECM there is only 3.28 voltages on the ECM going to the temperature sensor and there is nothing like continuity connection. sir it is possible the ECM is so broken sir. Thanks
Feb 2, 2018 at 6:24 PM
Okay, there is supposed to be a five volt signal sent to the sensor and the other wire is the return to the ECM.
if the connector does not have five volts, then I would check the ECM connector in the attached diagram. if the five volts is not present at the output of the ECM, then yes, it needs an ECM.
Feb 3, 2018 at 5:16 AM
CID6688
  • 9 POSTS
Sir, I check the ECM but there is only 3.28 voltages on the ECM. Is that enough?
Feb 3, 2018 at 6:29 AM
No, five volts is what the reference voltage should be.
if you only have 3.28 volts, then the ECM has failed.
Feb 3, 2018 at 6:33 AM
CID6688
  • 9 POSTS
Okay sir, thank you so much.
Feb 3, 2018 at 6:36 AM
You are welcome. we are here to help.
Feb 3, 2018 at 6:37 AM
CID6688
  • 9 POSTS
Last question sir. Can ECM be repaired?
Feb 3, 2018 at 6:39 AM
No, you need special equipment for that. You need a new ECM, then it needs to be flashed or programmed to your car and keys.
Feb 3, 2018 at 6:41 AM
CID6688
  • 9 POSTS
Hi sir. I have a question again. If the temperature sensor's voltage dropped, will it affect the aircon as well?
Feb 3, 2018 at 7:20 PM
no, not at all. the only time is if the engine is severely overheating, the compressor will be disabled.
Feb 4, 2018 at 5:34 AM
CID6688
  • 9 POSTS
How about the temperature gauge and the cooling fan? Will they get affected if ECM voltage drops?
Feb 4, 2018 at 5:45 AM
if the ECM voltage drops to the ECM, then nothing will work correctly.
a scan tool that reads OBD1 systems can read these voltages.
Feb 4, 2018 at 7:08 PM
CID6688
  • 9 POSTS
hi sir this is my ecu faulty with parts #39117-03012
And i replace defferent parts # 39117-03002
It is ok for my car?
Feb 7, 2018 at 4:00 AM
No, the numbers must be the same. if you install the other one, it may not work at all.
Feb 7, 2018 at 4:02 AM
CID6688
  • 9 POSTS
thank you sir roy, I can not buy it here in our area. need to buy online
Feb 7, 2018 at 4:11 AM
ok,
Check this site. www.car-part.com
Feb 7, 2018 at 4:37 AM
