at idle or slow traffic my temperature gauge rises and my heater blows cool air
2000 GMC JIMMY
250,000 MILES • 0.6L • 6 CYL • 4WD • AUTOMATIC
MWIRE134
Hi, I hope you know what causes this. When I am at idle or slow traffic my temperature gauge rises and my heat turns cool. So I put it in neutral and rev up the engine to around 3800 rpms for a little bit and the gauge goes back down and the heat comes back on. Everytime! I already changed the thermostat to an AC-Delco so I know its not that. I have checked the belt and the coolant level and they are fine. I thought I would change the radiator and while I was in there the water pump also. But I would hate to spend the time and money and find out it is something else. Is there anything else I can try or have you seen this problem before? Thank you. Sincerely Marty.
Dec 28, 2016 at 2:06 PM
JOHNNY G.JR
  • 320 POSTS
Sounds like system has air in it,needs to be bleed
Dec 29, 2016 at 1:30 AM
MWIRE134
Thanks JONNY G.JR. It most certainly was air in the system. Bled it through a bleed plug just below the thermostat housing and everything is working fine now. Thanks for saving me a lot of time and money. Sincerely, MWIRE134
Dec 29, 2016 at 2:23 PM
Glad you could get it fixed please use 2CarPros.com anytime we are here to help
Best, Ken
Jan 3, 2017 at 1:30 PM
