Okay, so I have had lots of issues since a multi-state trip (years ago) which caused a major meltdown if you will. A few issues have been solved here so thank you!
The engine temperature gauge (I assume the name) on the cluster constantly digs. This happens regardless if the car has just started.
The car will go ten minutes and it randomly starts digging in a very staccato fashion. Sometimes it is not immediate and will go twenty to thirty minutes and sometimes not at all.
I have replaced the coolant temperature sensor with no resolution of the issue.
I am wondering if it is a false positive or if it is an actual issue resulting from the previous major issues. (below they are described)
Latest: The head gasket had a coolant leak which cause the engine to lock up, had a friend (mechanic) help out and we replaced properly and cleared all out coolant found as well.
Earlier:
• Oil sender replaced due to a heater caused hole in sender causing leak.
• Radiator (leaks) and fan replacement (stopped working).
Earlier:
Sep 27, 2018 at 12:08 AM
