The vehicle has an engine vacuum controlled mode door actuator. That is the actuator that directs airflow. Now the interesting thing is there is one for defrost and a different one for panel and floor airflow. That leads me to believe there is a vacuum leak.
With the engine running, listen closely for any hissing sounds coming from under the dash. That could indicate a leak.
Next, I attached a pic below showing the defroster vacuum motor. Check the hose going to it to see if it is dry rotted, damaged, or loose.
Also, I'm including directions to replace the panel/floor actuator. This is to help you locate it.
2000 Ford Taurus V6-3.0L VIN U
Panel, Floor Console Door Actuator
Vehicle Heating and Air Conditioning Air Door Actuator / Motor Service and Repair Procedures Air Door Actuator / Motor, HVAC Panel, Floor Console Door Actuator
PANEL, FLOOR CONSOLE DOOR ACTUATOR
REMOVAL
1. Remove the floor console. Refer to Console.
pic 2
2. Remove the right-side instrument panel insulator.
pic 3
3. Working the passenger footwell, remove the floor console register duct vacuum control motor.
1. Disconnect the vacuum hose.
2. Remove the screws.
pic 4
4. Rotate and remove the vacuum control motor from the floor console register duct door.
CAUTION: Do not attempt to bend any part of the floor console register duct door lever.
INSTALLATION
1. To install, reverse the removal procedure.
As I mentioned. Since you have two actuators having trouble, it sounds like a leak and not one of the actuators. If you check the two things I suggested, start the engine and move the hoses around to see if you can hear a leak.
___________________________________
Take care and God Bless,
Jun 22, 2021 at 11:30 AM
(Merged)
