Temperature gauge intermittently not working
2011 VAUXHALL ASTRA
35,000 MILES • 1.6L • 4 CYL • FWD • MANUAL
HENDO46
Noticed temperature gauge not moving above zero and heater only blowing cool air even after travelling twenty miles, sometimes the gauge rises to about forty degrees and the heater blows hot but the gauge will drop to zero and the heater will blow cool again, the gauge used to run at ninety degrees.
Dec 5, 2016 at 9:51 AM
STEVE W.
  • 15,113 POSTS
First thing is to check your coolant level, low coolant could cause this. Next would be to remove and replace the thermostat. If they stick open the engine won't warm up properly.
If you have access to a scan too or even a lower end tool that will read live data it can show you the temperature the coolant sensor is reading.
Dec 5, 2016 at 6:22 PM
HENDO46
Thanks steve, coolant level is ok, will change thermostat an let you know outcome
Dec 6, 2016 at 12:56 AM
MHPAUTOS
  • 31,937 POSTS
i agree, the thermostat would be the first thing that i would be checking.
Dec 7, 2016 at 4:33 AM
HENDO46
Changed thermostat everything now working as it should, cheers guy,s and thanks for the advice
Dec 8, 2016 at 11:30 AM
STEVE W.
  • 15,113 POSTS
No problem, enjoy the heat..
Dec 8, 2016 at 12:38 PM
MHPAUTOS
  • 31,937 POSTS
Thanks for using 2carpros
Dec 8, 2016 at 11:46 PM
