I replaced the temperature sensor and disconnected the battery. Drove great for 3 days then temperature gauge stopped working again. Dash says engine hot/AC off. Then the fan kicks on, A/C doesn't work. If I unplug battery and reset it, it will run for a day or an hour, it is always different, but it also will start working randomly also when driving. Can it be a ground, a module or the instrument cluster? Need help! Did change the thermostat also. If the thermostat is stuck open could that cause the temperature gauge to stop working?
Feb 21, 2022 at 10:46 AM
