Temperature charge and A/C not working
2008 CHEVROLET BLAZER
140,000 MILES • 4.2L • 6 CYL • 2WD • AUTOMATIC
FADI DERGHAM
The temperature charge also A/C not working. sometime while the temperature was working A/C was working. I did scan the car it appears three sensor. I have changed the coolant sensor what ever. I could not identify the problem. if you know problem respond me. My friends if you can tell which sensor have to change it or another problem. Thank you.
Jan 17, 2018 at 4:43 AM
STEVE W.
  • 15,113 POSTS
I am sorry, do you mean the temperature gauge on the dash is not working? If so the coolant temperature sender on the rear of the cylinder head feeds that signal to the computer.
From your description I would check the wiring at the sensor connection and back to the power train control module. The wires break right inside the connectors or in the wiring harness and you get no signal. If you have a scan tool put it on live data and watch the coolant temperature PID while you move the connector and wiring around. If it suddenly works you are near the problem.
Jan 17, 2018 at 6:00 PM
FADI DERGHAM
To steve
Yes, I mean it exactly as your description as problem’s . Thanks for your advice . As soon as possible I check it I shall tell you what happen .
Jan 18, 2018 at 2:05 AM
