Just recently my car Temperature gauge will climb to hot and sometimes it will start to ding. I can shut it off and start it back up and the needle will go back down. When I drive with a scan tool hooked up the Temperature never goes above 164. Voltage does not go down past 2.32 volts. Should I change the Thermostat since it's only reading the coolant at 164 degrees. OE temp for the Thermostat is 195 degrees. Could this be a coolant flow problem, Temp sensor but it seems to be reading fine. Voltage and temp isn't erratic, possibly the Thermostat is opening to soon?
Jan 13, 2017 at 10:05 AM
