A couple questions for you to help solve your issue.
First, is your engine coolant level topped off to manufacturer specifications? Next, when the car is running (after the ten minutes) do you have heat from the heater vents?
If the answer to both those questions is yes, then have you checked the coolant temperature sensor? Some cars have two. One of them would go to the engine's computer to regulate air/fuel mixture, and the other would go to your gauge in the dash.
The other option is that you could possibly have a bad gauge. That would be the last thing to address. Some vehicles pick up their data (even for that of temperature) from the temperature gauge.
Keep me posted on what you find and let me know if I can be any more help!
WIlliam
Dec 1, 2018 at 8:35 PM
