not sure I can run the tests in FORscan. I connected and cleared all codes (DTCs would not fully clear). What is in logs is persistent.
===TPM DTC None===
Successful DTC reading, no error codes found
Module: Tire Pressure Monitor
===END TPM DTC None===
===GPSM DTC None===
Module: Global Positioning System Module
===END GPSM DTC None===
===FDIM DTC None===
Module: Front Display Interface Module
===END FDIM DTC None===
===PCM DTC None===
Module: Powertrain Control Module
===END PCM DTC None===
===OBDII DTC None===
Module: On Board Diagnostic II
===END OBDII DTC None===
===APIM DTC U0256:00-2B===
Code: U0256 - Lost Communication With Front Controls Interface Module A
Status:
- DTC Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
Module: Accessory Protocol Interface Module
===END APIM DTC U0256:00-2B===
===OCS DTC None===
Module: Occupant Classification System Module
===END OCS DTC None===
===TCCM DTC None===
Module: Transfer Case Control Module
===END TCCM DTC None===
===RCM DTC None===
Module: Restraint Control Module
===END RCM DTC None===
===PAM DTC None===
Module: Parking Aid Module
===END PAM DTC None===
===PSCM DTC C1B00:62-0B===
Code: C1B00 - Steering Angle Sensor
Additional Fault Symptom:
- Signal Compare Failure
Status:
Module: Power Steering Control Module
Freeze Frame :
-MOD_SUP_V: 11.75 V - Module Supply Voltage
-PWR_MODE_KEY: Accessory - Power Mode Key State
-PWR_MODE_QF: Eval in Progress - Power Mode Quality Factor
-SW_ANGLE: 0.00 ° - Steering Wheel Angle
===END PSCM DTC C1B00:62-0B===
===BdyCM DTC B10F1:14-0A===
Code: B10F1 - Key In Switch
- Circuit Short To Ground Or Open
Status:
Module: Body Control Module
===END BdyCM DTC B10F1:14-0A===
===SCCM DTC None===
Module: Steering Column Control Module
===END SCCM DTC None===
===IPC DTC None===
Module: Instrument Panel Control Module
===END IPC DTC None===
===ABS DTC None===
Module: Antilock braking system
===END ABS DTC None===
I also ran live scan on FDIM...(see pic)
For replacement parts. I replaced the climate controls BL3T-18C612-DF, last October (per eBay purchase). This unit worked well for a couple months then began to bug out. rarely, progressively getting worse.
My stereo completely quit working, no audio (was 6disc)...I swapped w/ the JVC in the video, I have iDataLink and setup with SYNC integration. (This was done June 2020)
When I did all my test/scans tonight the HVAC was working the entire time, I might have to wait for it to fail to see where the problem is?
Apr 15, 2021 at 2:06 PM
