My HVAC system is blowing cold air. No heat. Everything else switches like it's supposed to on the dash, except the button switch from cold to heat. I am trying to make an exact location of this temperature blend door actuator. My suspect location is behind the glove box. If this correct and if so, will I avoid having to completely remove the dashboard? Is there a reset on this repair? If so, how is it to be done step by step?
Oct 31, 2023 at 3:43 PM
