Engine will not stay running?
2002 VOLKSWAGEN BEETLE
200,000 MILES • 1.9L • 4 CYL • TURBO • 2WD • MANUAL
RODRIGOVZQZ
  • 14 POSTS
car cranks and starts for a few seconds and then shuts off. The diesel pump was replaced by the dealer 4 years ago and was working fine. was automatic and turned into std. traveled 2,000 miles trouble free and all of a sudden started acting up. I had to push start it once in reverse and started smelling like burned, as in electronic wires. Any advice?
Oct 29, 2023 at 7:46 PM
I would check the wiring harness for the engine to make sure nothing got pinched when installing the manual transmission. This is typical when an R&R occurs. Next check the fuses this guide can help, please check the fuses with the ignition system on:
If all fuses are okay let's run the codes to see if any are stored.
Oct 30, 2023 at 11:14 AM
RODRIGOVZQZ
  • 14 POSTS
Got p0753 and it's manual not automatic.
Mar 8, 2024 at 12:05 PM
RODRIGOVZQZ
  • 14 POSTS
Another thing is, to try to start it, it drags with a new battery. Have to use jumper cables.
Mar 8, 2024 at 12:17 PM
It sounds like the battery is weak or you need a starter. Please upload a video in your response to the problem so we can see what's going on.
Mar 9, 2024 at 9:49 AM
