TDC sensor code
1994 ACURA VIGOR
293,200 MILES • 2.5L • 5 CYL • 2WD • AUTOMATIC
VIGOR94
Installed new distributor after removing original oil soaked in cap. Ran For sixty miles then car stalls at stop sign or red light. Then day later starts then shuts off. Restarts and will not idle, period. Check engine code is eight flashes. Shows TDC sensor.
Jan 29, 2018 at 7:07 PM
MHPAUTOS
  • 31,937 POSTS
can you post the actual code set? this will help with the diagnostics.
Jan 31, 2018 at 1:39 AM
