Car will cutoff when brake pedal is pushed and TCS light is on
2004 HONDA ACCORD
120,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
MRHAPPY123
Alternator and battery are good. I believe problem is with the ABS system, what are your thoughts on what it could be. TCS light is on indicating a problem.
Apr 10, 2019 at 12:35 PM
This light comes on when there is a problem with the ABS which is usually a wheel speed sensor. To be sure here is a video on how to run the codes and a guide to help you test the sensors without scanning it:
https://youtu.be/rTtAnsOlZU4
and
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
Apr 12, 2019 at 10:48 AM
