Code U0101
2010 MAZDA 3
95,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
JCOLE302
Have a code U0101 which points to the TCM Being bad. I’ve been told on this model with a 2.0 the ECU does the job of a TCM. Does my car have a separate TCM?
Mar 30, 2022 at 10:26 AM
This code is just pointing you to a TCM due to it not communicating on the bus network.
So that could be a module or a wiring issue, so I am attaching the info about this code and system.
The TCM is located on the driver side of the engine compartment.
Here is a guide that will talk about this type of communication network:
https://www.2carpros.com/articles/can-scan-controller-area-network-easy
Please see all the info attached and let us know what questions you have.
Thanks
Mar 31, 2022 at 3:56 PM
