This vehicle doesn't have a separate module for the transmission (TCM). Instead, the transmission is controlled by the powertrain control module (PCM). It is located at the front left (driver's side) of the engine compartment.
I attached the wiring schematic below, so you have a reference.
joe
See pics below. Note: I had to cut the schematic in half to make it readable. I did overlap the two so you can follow from one to the next.
Apr 7, 2024 at 7:04 PM
