Car has TCM codes, including "implausible data" code. Upon inspection using my Autel scanner, the engine speed reported by the TCM is 3300 with the engine off. This is true through two separate TCM units. I have reset and re-initialized both units, both with no change. The procedure cannot be performed because the "engine is on", which it is not. What feeds the TCM the engine speed information? Does it come from a sensor, but through the PCM? Or directly from a sensor? I don't want to condemn or pay to re-flash the TCM if that won't solve the problem. The fact that the information is consistent (wrong) across two separate units leads me to believe there is something else to blame.
May 8, 2023 at 1:48 PM
