No start and gear selector light on the dash board is not showing
2004 MAZDA 2
200,000 MILES • 1.4L • 4 CYL • 2WD • AUTOMATIC
CAROL CHEKZ YOMZSYABZ
  • 5 POSTS
Hello, does my car have a TCM? The problem I am facing is; the gear selector light on the dash board isn't showing, hence, the car can't start, have seen video's showing replacement of the Transmission Control Module solving this, but not sure if mine has one
Dec 4, 2019 at 1:16 AM
We don't have this car in the states but I would start by checking the fuses. here is a guide to help you with the test:
Have you checked the battery?
This guide can help:
Dec 5, 2019 at 11:07 AM
  • 5 POSTS
Hi Ken,
The fuses were my first suspect too and I replaced all of them that were burnt out and the battery is fully charged, however, still having the same issue.
Thanks for the response.
Dec 7, 2019 at 11:19 AM
You have a 7.5 illumi fuse with the key on does it have power? Here is the wiring diagrams so you can see whop the system works. Check out the diagrams (below). Please run this test and get back to us.
Dec 8, 2019 at 11:46 AM
