Hi and thanks for using catalytic converter
The computers need relearned to make the shifts correct again. It requires a live data scanner. I have basically cut and pasted information related to this. According to the repair manual, when the TCC is replaced, this needs done.
The transmission adaptive pressure (TAP) information must be reset. Resetting the TAP values using a scan tool will erase all learned values in all cells. As a result, the ECM, PCM or TCM will need to relearn TAP values. Transmission performance may be affected as new TAP values are learned.
Here are the directions and a better explanation.
The PCM maintains the Up-shift Adapt parameters for the transmission The PCM monitors the A/T ISS sensor and the A/T OSS during commanded shifts in order to determine if a shift is occurring too fast or too slow. The PCM adjusts the signal from the transmission pressure control solenoid in order to maintain a set shift feel. Transmission adapts must be reset whenever the transmission is overhauled or replaced. In order to reset transmission adapts, select the following:
1. Tech 2
2. Special Functions
3. Transmission Output Controls
4. Clear TAPS
I hope this is helpful. Feel free to ask other questions if you have them.
Nov 7, 2018 at 4:57 PM
