Where is the TCC located?
2002 FORD F-150
63,000 MILES • 4.5L • V8 • 2WD • AUTOMATIC
DREDRE702
  • 6 POSTS
Can't find the location of the torque converter control solenoid.
Mar 7, 2025 at 12:31 PM
The torque converter control solenoid is on the valve body with the vio/yel wire. You should remove the pan and trace the wire to the solenoid in question. Check out the images (below). Let us know if you need anything else.
Mar 8, 2025 at 10:31 AM
