hi guys, now here it is: prior to this noise i have changed the camshaft sensor, VVT solenoid sensor, coil packs, spark plugs, valve cover gasket. i flushed drained engine oil twice then replaced with a new filter and oil. i also noticed while in the engine the timing chain had about half an inch play as in loose. could that be the issue? i'm not sure. anyhow now i'm getting this tapping in the engine. once or twice it won't be there for about a minute then after that it starts tapping .
i have attached the link to video , maybe one of you can help me figure this tapping out. thank you in advance
here's a video link if the uploaded video don't play.
https://files.fm/u/pzqp9c9h7
Aug 4, 2021 at 1:33 AM
